debutis
- July 2, 2002
- austin, texas
- 98 eddie bauer
I am trying to install my new sony indash 7" screen. I'm having a pretty severe problem. I'm trying to hook everything up and make sure that it works before I make the final touches and hook it into the dash. So I have all the wires laid out right now and most of the wires are hooked up. On the sony headunit, the only wires not being used is the Blue wire that is used for aftermarket amp and says no more than .3A. Also, the only stock wires not being used is a thin black/green wire used for amp grounding and a black wire which is used for the dimmer ground. Neither of these were included on the sony headunit. Anyways, when I put the keys in and turn the car on, NOT starting the car, a click sound is heard. It almost sounds like the starter is click over and trying to start the car but I had a friend look at it while I had the keys in and he said it sounds like it's coming from the fuse box under the hood. Anyone have ideas as to what the problem is?? I'm not even sure it is coming from the fuse box. Anyone help me?
Thanks,
Matt
Thanks,
Matt
