Intake manifold gasket. | Ford Explorer Forums
landmik
98 eddie baur
in the process of replacing lower intake gasket on 4.0 l EFI [vin x] type on 1998 explorer any suggestions
thanks
thanks for the reply but I need information on the OHV not the SOHV 4.0
The only real tip I can give is leave the fuel rail on the lower intake. If you must take that apart (say you want to change the o-rings), put the fuel rail on the lower intake before you put it back on the motor. Getting all the o-rings lined up when everything is in the truck gets a little tricky and you can easily pinch a o-ring.
If you do change those injector o-rings, put some cooking oil on them for lubricant (no petroleum based oil).
Are there any specific things your wanting to know about?
~Mark
thanks
that looks like it is just what i need complete with color pictures don't get better than that, we shall see!!
we have victory all gaskets replaced running better than ever! Thanks again Rangerx
Glad to help, but the real thanks go to the guy who did that step-by-step in the link.
Mine's running good, too. :thumbsup:
