I'd like to end up around 14lbs boost. Not sure if I will get there though.
Im not pulling my heads again (Unless things go horribly wrong). I think I'd have to pull my motor, as the passenger side air cond box would be in the way.
I am not running lean (So says my a/f gauge) so I am pretty sure I have not exceeded the duty cycle of my injectors. Maybe that will change when I get my iat's under control?
Phix, do you have a picture of the underside of your M90?
That kind of boost, 14psi, with cooled IAT's, would approach being an airflow similar to a 7.0 liter engine. Every 14.7psi is one multiple of displacement flow, potentially. With hot IAT's like you have now, the effective extra airflow is far less. The incoming air is so much thinner due to the temperature.
Plan your exhaust based on what final effective airflow you hope to reach. If you might get to 14psi with a good IC system, then expect to need sizes for a 400+ CI engine for your rpm level. I'd begin planning for that kind of exhaust. If the current pipes to the collectors are not 2.5", I'd start right from there, and build a full dual system. I would make a big bet that the engine will need that greatly. It sounds like that would be double the capacity the current system is. I think if you did the exhaust first, it will not bring IAT's down much, but with a tuning session, it would be quicker for sure.
BTW, two mufflers would have half as much exhaust running through each of them, which will reduce the sound. That will allow you to relax on issues like a resonator or super quiet mufflers.
I prefer less sound, so I'm always shooting for the quietest choice. I will begin my Mountaineer project with the exhaust, and the pair of Vortex mufflers I got a few years ago. I loved that they are flat and will easily stack together, I expect them to be right at about 8" tall, tack welded together.
There is tons of room for the exhaust from the collectors to the rearend, the headers and tailpipes are the tough parts.
