shlompyboy
- April 25, 2000
- Portland, OR
- 93' XLT 4X4
so my interior lights won't shut off when i close the doors.i have pulled the fuse for them, but this also leaves me without a radio..i have run a few searches about this problem, and all i could come up with was that the on/off mechanism is located within the door latch itself or something..could someone please elaborate on this a bit?..it suckz having no light or music..could it also be possible that the little round rubber thingies the door latches onto could be the problem?..as they are a bit worn through, and prevent my door from closing at all sometimes..i have wiggled them all (as this has solved the problem before), and the light dimmer switch is set correctly..any help would be greatly apreciated..thanks..
jeremy..
jeremy..
