Is a Dana 44HD from a '77 as good/strong as one from a '78-79? Found one cheap.
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
I read the article but is there a code breakdown sheet somewhere posted that I can check the i.d. numbers with on the axle tube to make sure it's what he says it is and the axle I want?
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
http://77cj.littlekeylime.com/BOM_Info.htm
MidnightRebel07
Pittsburgh, Pa.
You the man, thank you!!!
MidnightRebel07
Pittsburgh, Pa.
Talked to the guy and found out it is setup for leafsprings and is 8 lug. Going to check it out tomorrow and possibly buy it. He has new spicer ball joints and bearings, seals, dust shields, rotors, etc... He also has the leafsprings from the truck as well, should I get those or go with a set of Grand Waggy leafsprings?
sport97
Elite Procrastinator
connellsville pa
1997 sport SOHC 4.0
Where is the axle located at, Jerry?
N2FORD
Kingston,TN
2001 Sport Trac 4wd
Not trying to hijack this thread but I also a Sport Trac that I am planning on doing a SAS on. I bought a 76 or 77 Bronco frame with a D44 still attached. Does anyone know if that is one of the better ones? Any comments good or bad?
MidnightRebel07
Pittsburgh, Pa.
Depends on if it's open or closed knuckles, u-joints sizes, axle tube thickness and if the wedges are welded or cast on. Check out the links Gman posted on the 1st page of this thread and it'll tell you the differences of the axles.
Vince, he lives over in Brentwood.
MidnightRebel07
Pittsburgh, Pa.
LOL. nice Hugh, real nice. LOL
MidnightRebel07
Pittsburgh, Pa.
Damn, now I'm torn between getting a Dana 44 from a '89 Grand Waggy for $100 or this Dana 44HD from the '77 F-250 for $250. The HD is probably stronger and high pinion but also full width and 8 lug where as the GW is damn near even in perfect width, 6 lug or easily swapped to 5 lug but is low pinion. Decisions, decisions. What do y'all think?
MidnightRebel07
Pittsburgh, Pa.
Then I gotta change out the rear axle with a full width= more $$$. I'm really torn because I wanna have the swap done by next summer at the latest. If I had all the money up front I'd just buy Chad's rig, wheel it and slowly build mine.
gmanpaint
Staff member
Moderator
MO MO
94 & 95 XLT's
What axle is going in the rear?
Keeping the 8.8 with 5 on 4.5" lugs?
Swapping to a full width 8.8" with 5 on 5.5" lugs?
Swapping to a 9" or 10.5" rear?
Do you care to run 2 dif size spare tires or prefer 1 spare that fits both axles?
Be easier to swap in the waggy axle and keep the stock 8.8 in my opinion, but easier might not be what you care about. :dunno:
Edit: Took too long posting this and you have already thought about the rear axle!
MidnightRebel07
Pittsburgh, Pa.
Ya, I'd like to keep the 8.8 and do what Stang did on his Mounty with the Yukon C clip eliminator setup so I can do different bolt patterns if needed. I think I may just get the Waggy 44 and build it up. I can post a link for the '77 HD axle if anyone is interested. Too many things happening at once right now tying up funds to build what I really want to do. Lol, never fails.
sport97
connellsville pa
1997 sport SOHC 4.0
The waggy one allows you to keep the 8.8, so in the end is cheaper really. Not knpwing much about the advantages of either my vote is on the one from the jeep. I think in the end either way it'll wheel most of what you throw at it. Especially because there aren't many PA guys that are all set up to wheel crazy. I'll probably try the f150 out in the woods next time we go out (maybe). This particular explorer will probably move down the road after the truck is refurbished to purchase a gas friendly car. Then when I get a house with a garage i'll be following in your steps with a RBV SAS.
Xeek
Virginia Beach, VA
1991 xlt
if its early 77 its low pinion. do you have a pickupull around? it wouldnt be to hard or expensive to go there and get a sterling to match. if it ends up a high pinion, i would get it. if its low pinion, i dunno.
they always say you never stop upgrading, ttb ends up d30 or d44, d44 ends up d60, d60 ends up upgraded, then a select few say screw it and go rockwell
dkchrist
Fayetteville, AR
93 XLT 4DR
If it is high pinion, the 77 is the way to go. The driveshaft angle is lower helps with life, allows more droop, and a big plus is the gear strength.
The conversion to 5 lug can be done with dodge or ford knuckles depending on if you want flat tops or not.
jperry7783
Beckley, WV
96 sport
The axle you pick depends on what you want to do with the truck. I had an early Bronco 44 under my explore for a while. It was a good axle, but the truck felt unstable all the time. I put an f250 hp 44 in it and was much happier. The stability was a great improvement.
MidnightRebel07
Pittsburgh, Pa.
Was supposed to go pick up the axle today, talked to the guy two days ago and yesterday. Called him today to let him know I was on my way and he let me know they were gone. WTF man, what happen to people. When I'm selling something or even giving something away for free if someone contacts me I hold it for them.
The search continues.
