kmmac1705
- August 13, 2006
- Tennessee
- 91 E.B. 4x4 Explorer
Today I replaced my radiator in my 91 eddie baur ( it had a crack in it) . When I got it all done I went for a ride it was fine . When I got back I left it running and checked under it for leaks . I found one coming out of water pump at shaft. My question is can you take it apart and replace a seal in it or do you have to replace the whole thing. Also could it have caused the preasure to crack radiator. Cause I had no pressure before now when I take off cap it whooshes air . I also found a line on my transfer case on the back top of it plugged off. Does any body know what it is supposed to be hooked to . My 4x4 don't work Thanks for any help!
