Ford Explorer Maintenance - Modifications - Performance Upgrades - Problem Solving - Off-Road - Street
The "scratches" running up and down are your issue. Looks like the rings did not "break in" and seal, or, metal shavings got into the oil. re hone and re ring should get it.
ah. well i think i had 700 miles on it and went off roading. didnt do many high revs until i got stuck, tried for a few mins then gave up. when it got to about 2000 miles i took a road trip and beach in 4lo. no OD, 3k at 65mph most of the way.
so i guess that explains it. i burned/leaked 1 quart of oil every ~150 miles. leaked some from the bolt that was screwed up in the timing cover.
valves, intake, heads are all covered in oil/crud from the oil vapor coming in from the tube off the valve cover to the intake.
its gonna be bored this time. how much and what pistons will be a secret for now
agree and disagreei totally agree he did not break that motor in right and the walls should have been honed in the first place.but think those up and down scratches are from hydrolocking.water and mud getting into the cylinders.the walls are worn REALLY BAD compared to what it was when put it together.they looked new,nice smooth hatching then.they look like polished glass now and you can almost see ring worn step marks.ill be going over sat and probably know a little more then
i have no idea what a collapsed lifter looks like. but if its as simple as the outer plunger being below the lifter body lip, then yes. those two were a pain to take apart due to that. i had to spray stuff in the hole on the side of the lifter in small bursts to try and force the plunger out.
i had a set from the junkyard that was just as much of a pita to take apart and those springs werent broken. so this surprised me lol
so i further found out the 2nd piston comes apart even more... a cap with a TINY TINY TINY TINY spring and a ball bearing.... id really love to match up some spares and make a set of 12 refurbished by me. cause i know theyre expensive...
this is how the outside of all of them look like:
and i think once i completely finish the 'teardown' and nothing else exists to learn from and its moving towards starting from scratch ill make a new thread.
yea you can see the lip i meant in the last pic. 10 had the plungers past that, those two didnt.
im just wondering if mine are good to reuse.. due to all the wear on the bodies
Light surface scratches on lifters are going to happen, even to brand new ones. As long as they aren't gouged or dinged they will be fine to re-use.
You'll still be using old springs though. I wonder if there's any way to get a kit of all the replacement springs. A rebuilt set of factory lifters with all new springs would be great and be a nice way to get out of the cost of replacement lifters, and probably better too, as long as the new springs are better than the ones that were in there.
Nice going on taking apart the lifters. I'd guess the busted springs are what causes these to collapse.
hell if i could find where to buy new internals id do it. im not paying $350~ for 12 sealed power lifters.. and from someone elses experience the $100 ebay ones werent that great..
dono, i remember seeing one, but it was just text. i may aswell do a picture write up. itd be easier if i had someone with me to take the pics. so i may wait on doing it
I just picked up some paint thinner, and set the doner motors lifters in the liquid.
This motor was a low miler, it probably would have been nice if it had an oil change in the first 100,000 Kilometers(guessing, but probably a good guess).
Well I just got my granny to take the pics for me lol. So ill make a write up for it.
Honestly, take then apart then soak them in teanny fluid.
I let mine soak in diesel kleen for a week before I took then apart. Just cause I had a bottle in the garage and didn't own a diesel anymore lol.
