Welcome to the forum Rocco1005. You should be able to go to a different size tire, but it will change the reading of your speedometer, & it might have an effect on your gas mileage. I do not know if it will change anything else.
Welcome to the Forum Rocco.
A 265/50R20 will only have a nominal 1% difference in diameter variance. When the speedo reads 60 mph you will actually be going 60.8.
Watch those radars.
Watch those radars.
I think Peterk9 is right; while 255 to 265 seems like you’re only changing width, 50 represents a ratio of height to width (or vice versa) so the new tire will have a larger diameter than the old one.
Will the size change save you money? Just wondering if it’s worth the trouble. I use the engineering mode to calibrate the MPG meter but I’m not sure if you can calibrate speedometer that way.
I would think that it would likely result in slightly lower MPG since you are now pushing a wider tire and will likely add a bit more 'rolling resistance. A wider tire would also be more prone to hydroplaning and harder to push through snow. Personally, I'd stick with the OEM size.
I checked the sizes on several tire brands and the differences vary somewhat. On some the 265 is slightly more expensive while on others they are slightly less expensive. So whether it will save you money to go with the 265 depends entirely upon which brand you choose.
