2010 Eddie Bauer
- October 29, 2018
- Olathe, Ks
- 2010, Explorer Eddie B.
I have a question for you all. When it is well below freezing outside, I will get a knocking noise from the front of my engine. It sounds as if it is coming from the bottom half of the engine. It only occurs upon a cold start first thing in the morning. I have the 4.0 sohc V6 with approximately 105,000 miles on the clock. It lasts for approximately a minute or so before it goes away. It does not occur upon every cold start, but does most of the time. It disappears upon putting the transmission into drive. I bought it used with 85,000 miles and have changed the oil every 3,000 miles with Mobil One full synthetic since I have owned it. I heard of the dreaded timing chain problems and installed a pre oiler about a year ago to prevent issues. This noise still occurs after the engine is pre-oiled. What could be causing this?
