ld50 Explorer mods revisited | Page 11 | Ford Explorer Forums
Who needs to work when you can read a 9 page post like this. Very inspiring, only wish I was a bit more mechanical to do a lot of those mods myself., specifically a suspension lift so I can fit 33s on.
Thanks guys,
Hey it is not that hard, I practically did it all alone except the gears and locker, Just gotta find a way to have acces to all the tools. :D
FENDER FLARES
Okay I mentioned there was 4x4 traps being seen around where I live. Apparently it is more accurately a trap to catch large trucks, but they are pulling in lifted 4x4 vehicles as well.
I have been told that a "passenger vehicle" which is what I am classed as, cannot exceed a bumper hieght of 22 inches from ground to bottom of bumper. Well I`m 24 inches. I won`t try to lower them, but I thought at least I could make my truck look less like a violator, and hopefully avoid being measured.
[I am still finding out more about these laws, and I think If your bumper does exceed the height limit (some geek in an office has conjured up and fed to a room full old cronies who have okayed it) then it is grounds for an inspection order to be given, wherupon a test facility will test it as a "modified" rig. I don`t think it is ilegal to be higher, just that it will have to have a special inspection. I find so much different info that it is confusing.]
I cannot find a definite answer on how far my tires can stick out, it varies from 1&1/2 inches to nothing past the lip of the fender. "tiessen" from the board told me about some generic flares sold at Lordco, which is a local auto parts store.
I found these flares made by "Saddleman" which screw into the lips of your fenders. They cover my tires now, and don`t look that bad I guess. I would rather not have them at all but...
I got some mudflaps that were generic and put them on the rear, to further add to the look that everything is legal. LOL they really don`t do much, I`m afraid!
Rear:
They are on there really tight, with like 14 screws in each one. I had two drills going for the install, one for drilling, and then while holding the flare in place I put the screws in a magnetic bit I have, and screwed them in. After, I went over them with a screwdriver and loosened some, and tightened others to make it look as smooth as possible.
Front:
Looking good, how about mass producing that antanna mount? I would love one of those.:D
I agree looking good. I can't wait to get mine.... soon? I'll e-mail ya.
carsonm
:D
I can`t even get it together long enough to make one for Carson lately!
It actually takes me a couple hours with all the fitting and messing around, wouldn`t be enough payoff to spend that much time at work.
Next Episode:
Old Man Emu rear leaf springs!
Mine are no good after the Zimmerman mod, The Ranger leafs are bent laterally, as I have mentioned.
one of the best posts i have seen...ever...motivates me!!!
everything i wanna do and more!!!:D
oh no... I started reading your post to see what was involved in putting 31x10.5's on my 94 ltd... Now I need to get a 2" lift and some sleep... Awesome work, dude... Truly inspiring!!! Can't wait to mod my X for next winter... You know it gets pretty bad here...:eek:
:D you`re new here, you can still break free before you become addicted!
Welcome to the single most greatest Explorer site on the net!
-"Winterpeg" (inside joke)
:D
OME-36 spring bushings
(thanks guys)
Well I have the springs but I made a mistake when I got the bushings to go with them. I just asked the 4x4 shop to get me a bushing set "for the springs".
So I ended up with a bushing set meant for a stock 93 Explorer spring.
What I had missed was the fact that these OME springs are actually designed to fit a 96 Ford Explorer!
The springs are of course interchangeable from a 96 to a 93, it is just that the eyes in the spring are larger up front, to accomadate a larger bushing.
The bushing at the rear of the truck is the same size. I don`t know when Ford went to a larger forward one, but I assume it was when they moved to the 2nd generation in `95.
I found that out by searching the site here and finding it talked about. Even though I read through those posts before It still didn`t click! :rolleyes:
Anyway, It looks like I will actually have to get the forward bushings from Ford because I can`t seem to find an aftermarket poly for some reason. When I think about it, a rubber one up front may be better after all.
I hope to get the bushings and do the install this weekend.
Okay, I got the Old man Emu springs on.
As I said, I ended up using poly bushing in the rearward side, and Stock ford bushings for the forward side. The forward bushing were ordered to fit a 96 Explorer.
I had to press them in myself, and I used a big vice and two big wrenches to assist. I wish I had a pic of that proccess, but I don`t.
The outside of the Ford bushings are not as wide as the inside is, near the metal sleeve, so I used the box end of one wrench that was big enough to push on the bushing without hitting the middle sleeved part. The other wrench`s box end was used to keep the other side of the sleeve from hitting the vice when it was pressed in.
The polys come in two pieces, and I used a mallet to bang them into place, and then used the mallet to bang the sleeves into the bushings.
Anyway, here`s some pics:
Gettin them on, no need to explain the process again ;)
Big difference over my modded up stock ones. They compress easier, but in a graduated way, which is part of the design if you look at them closely. They aren`t as stiff, and don`t snap back when you hit bumps at higher speeds, which keeps you from going sideways. I went for a little run today, and I am happy with them, although they were expensive!
Jim,
That last pic is too awesome, must be nice to have such acool playground.
Originally posted by X-1
Jim,
Ah beautiful BC wouldn't live anywhere else.
Glad to see you got out today James, did you go alone? I'll go next time for sure.
carson
I can be at that playground in about 45 minutes! Half hour later I can get a pick like that :D
-Did go alone Carson,with the family. I actually fully explored that trail with the big ditch and the steep hill that I got up that time but didn`t check out. It actually has a great view of Stave from there and definitely will be less crowded. Here`s a pic from up there. Had virgin snow everywhere even to the main lookout!
Well, I have reached a level that I think I will maintain for a while before doing anymore mods! There is stuff that I would really like to do, but maintenance is all I`m worried about right now. The biggest thing is my tranny seems to be acting up lately, not wanting to downshift into second without grinding like a *******, and going into reverse is almost a guaranteed grind. A couple times I heard a growl coming from down there at take off, which might mean my clutch is on the way out. I will definitely replace the clutch with something better when I do!
[edit] - I bled the clutch and am happy to say that my tranny is behaving much better, with only an occasional feeling of something catching when going to reverse-
I got broken into the other day and they buggered up my lock and stole my sub. I got the best alarm I could, basically pimped myself to the alarm installer and became his biotch. It was a good idea anyway, because of all the money I have put in it already.
If I look back, all I really think was NOT a good idea was the Zimmerman mod. Sometimes I wish I had went with 4.56 gears instead of my 4.10s but then I get on the freeway and like it. (but it is close!)
I`ll try to keep away from the mods anyway!
All costs in CDN funds !
Truck = $8500.00
Plasma white hid headlights = $39.96
Mini driving lights = $65.00
Filter adapter = $68.41**
K&N filter = $50.00
Window visors = $45.00
Cheap CB = $75.00
Antenna = $50.00
Tow hooks = $40.00
2" susp lift with shocks = $464.00 **
31x10.5 BFG T/A K/Os = $835.00
New lower ball jts. and alignment = $ 604.00
Fire extinguisher = $ 40.00
4.10 gears, locker, U-joints = $2635.37
2" body lift kit = $148.45
Shifter extension = $58.21
2" x 20' tow strap = $40.50
War1780 skid plates - $115.00 **
War153 shackles - $99.95 **
1.5" Wheel spacers - $504.87 **
Custom exhaust - $320.00
Dual battery parts approx. $85.00
2nd battery= $100.00
33x10.5 BFG MUD T/A KM (4)
minus sale of old tires (350$) = $578.84
Antenna kit 4' Firestick = $80.03
Lower shock mounts WAR161 = $51.55
Saddleman generic fender flares = $50.00
OME-36 leaf springs and poly = $900.00 **
Ford `96 bushings for front of leafs = $100.00
(** includes shipping)
Total "EX"penses = $16744.14
