No1Eman
- March 26, 2004
- Roseville, Michigan
- 2002 Explorer Sport
On my 2002 Explorer, I have had an intermittent problem that seems to have finally become permanent. My left rear turn signal and left brake light as well as my center brake light don't work. The right side works fine. My left running light works, and the reverse light works. The front left turn signal light works as well, although it flashes at a much higher rate than normal. No, the bulb isn't bad, nor is the socket bad...I swapped the socket with the one on the right, and the problem doesn't move. what wire is common to both the tail light AND the center stoplight? And where is it? Has anyone encountered this problem before? They are both on the same fuse and the fuse is good. I figure it has to be a bad wire or a short, I just can't seem to trace it out.
