Bobs2018ExplorerSport
- February 4, 2019
- Location
- USA
- Livermore, CA
- 2018 Explorer Sport 4WD
- Callsign
- KD6ANY
I wanted to share some of the things I've learned from the trials and tribulations I personally experienced, during my work to convert to a full-size spare tire:
First, I need to share that I have a 2018 Explorer XLT that originally came with the 3rd Row Seats. Not having any use for those, I followed the nicely-done thread (elsewhere in this forum) regarding how to remove that 3rd row, and convert the rear to the PIU-style cargo bay. Once that project was done, I was ready to get rid of the compact spare and go to a full-size ready-to-use spare.
Here are some of the hard-earned facts that I learned from my upgrade project:
So-called "civilian" Explorers typically come with 245/60 R18 tires, on alloy wheels (as mine did). I didn't like the "floating" feel of those tires, so, after MUCH research... I converted my tires a step down in size, to 235/60 R18, which surprisingly not only greatly reduced the floating feel, but it also gave me a tighter steering response... all without making any noticeable inaccuracies in radar-based speedometer readings. At the same time, I also purchased and installed 4 OEM Ford steel wheels on the ground ('cause I love the look!)... as well as a 5th one for use in a full-size spare conversion.
Now, the spare tire well opening is only made to accomodate TWO different size tires... either the compact spare tire that comes with the civilian version, or, the 245/55 R18 tire that comes with the PIU version. IF you try to put one of the original-sized ("civilian") 245/60 R18 tires into that wheel well, it will not go all the way down, as the circumference is just a hair too big. However, if you put a 235/60 R18 tire in there, it will just fit... as will the PIU-sized tire of 245/55 R18... but again, the OEM civilian-sized tire will not!
Therefore, that leaves you only two choices (other than to continue to live with that crappy mini-spare)... either use a 235/60 R18 for your new full-size spare, or, go with the 245/55 R18 size that comes on the PIU's... (but, keep in mind that the PIU-size is a full inch smaller in overall height, as compared to the stock "civilian" tires). This is why the 235/60R18 was a good compromise for me.
Additionally, you must also remove and replace the civilian rear trim/scuff plate panel (the one that forms the bottom edge of the hatchback door opening) with the one that comes with the PIU (Part # DB5Z-7842624-BC, black only), as the civilian scuff plate has additional plastic panel material that continues down into the spare tire well, and thus effectively blocks your ability to slide the larger spare tire all the way down into the well opening. This part will run you another $100 or so, but again, you'll need to swap-out this scuff plate in order to allow you full access to the entire spare tire well.... otherwise, no matter what you do, your new larger spare tire will not fit into the well!
Now, if you look at photos of the 5th Generation Police Interceptor Utility (or, one on the street), it looks to me (IMHO) that the stock tires they chose for the Interceptor seem to be too small-looking, in regards to how they appear when compared to the rest of the vehicle. It is for this reason that I chose a slightly-bigger tire, rather than simply doing a conversion to the Interceptor-sized tires, and its all worked out very well for me.
One of the issues that also became apparent was that you also need to get rid of your compact spare tire hold-down bolt, and instead, obtain the one used in the PIU's, as the steel rim is so much deeper than the compact spare's rim. The Ford part number for the specialized (and longer) hold-down assembly is DB5Z-1424-A. Note that, on some parts websites, this part is called a "stud", but on others, it may be called a "Stud - Front Suspension Arm"... for some ungodly reason! In any event, ignore the apparently-erroneous description and simply order it as a DB5Z-1424-A (about $21.34 from Ford), and you'll be just fine. You can also use the same plastic threaded cap that originally came with your compact spare (but, if you need another one, the Ford part number on that cap is 5F9Z-1424-AA... about $9.22 from Ford).
Lastly, one of the things I wanted to overcome was that IF I ever had to install my new spare tire onto the ground, I didn't want my TPMS monitors to be alarming that one was missing... so I also installed a matching TPMS unit into the spare tire. Even though my 2018 only monitors the 4 TPMS units on the ground, it will also automatically sense and remember any replacement TPMS-equipped tire I might install, without any extra programming (or alarms), so that is happily a non-issue here.
A final reminder, that NONE of this information is applicable to Explorers that have (or, if you wish to keep) the 3rd Seat option... because with the 3rd Seat option, there is only enough room to have a compact spare in there, no matter what!
Here are some photos of the completed spare tire in the wheel well, as well as the visible difference between the (shorter) compact spare hold-down bolt, and the (longer) one that must be used with a full-sized spare...
