Hey lmacmil,
DocVijay is right, had tools are all you need. I'll add a description of replacing / installing shocks incase there are any others wondering how to do it. Its not a hard job.
The rear shocks have one large bolt on the bottom (perpendicular to the shock) and 2 small bolts on top. The front have one large bolt on top (straight down on top) and 2 smaller ones on bottom. Just ordinary sockets and wrenches are all you will need. I'm in a southern state so there was no rust to deal with. But just the basic tools should do.
For the rear you will have to drop the spare tire and remove it to get easier access to the top of the shock. I let go the top smaller bolts first. The drivers side is a little hard to get to because of some "thing". Not sure what it is but there were rubber hoses coming out of it. I was able to reach in over this to get the drivers side top bolts out. Then I let go the bottom bolt and the shock falls right out.
For the front, the top bolt is probably easiest to access through the hood on each side of the motor. If I remember correctly its a 9/16 deep socket. You will need a good extension on the ratchet to reach it too. One thing I discovered is that when trying to loosen this bolt the whole shock rotates. I had a friend try to hold it while I turned the ratchet but he couldn't hold it. So then we discovered there is a nut welded on to the top of the sock. Using a 9/16 wrench through the wheel well we could hold the shock and loosen the top bolt.
The new shocks come with a strap that keeps them compressed. For the rear I left this strap on and first bolted the shock on the bottom. Then I got one of the smaller bolts ready, cut the strap and guided the shock into the right place. The new shocks wont expand that fast. The shock will then hold its self in place to put in the other smaller bolt and tighten everything.
I did the same for the front (leaving the strap on the new shock) but put the top bolt on first. Again using the wrench through the wheel well to hold it so I could tighten the top bolt. Then cut the strap and guide the shock into place and add the two smaller bolts on bottom.
And that's it.. I didn't take the wheels off or jack any part of the truck up.
Oh, one thing more. My X is a 2wd. If yours is a 4wd I think your front shocks will me much more difficult because I think the shocks are inside the coil springs. The rear ones will be the same. My father has a 91' 4wd and the front shocks are inside the coils. I'm not 100% sure if the 96' kept the coil over shocks. Just a heads up...
