Lifeguards sas registry | Ford Explorer Forums - Serious Explorations
will i guess it time i did one of theese :)
specs
Frunt
  • HP Dana44 out of 79 bronco welded diff...$500 (frunt and rear no gears)
    5.5: cage springs for F-150...................$260
    14" travl shocks..................................$50
    wild horses extended radius arms............$455
    used 4.88 gears off ebay.......................$50 i think
    reabuild kit..........................................$112.07
    Warn premium hubs off ebay....................$80
    Gear instal...........................................$300
Rear
  • Ford big bearing 9" 31 spline open diff
    motive 4.88 gears..............................$180
    re-build kit........................................$22
    instal...............................................case of beer :chug:
    stock 4 door drive shaft......................$25
    drive shaft shortining..........................$75
    stock 79 F-150 rear break line..............$dono
as i remember i wiil add more. on with the pics! :)
nice lookin rig man , ill be buildin one of these next for the wife lol now that my rangers pritty much done
where was that last pic taken
some where around Stirling lake by cisco grove.
niceee expo :D:D
did u use the stock steering linkage
the steering on it right now is a mix of 79 bronco drag link and explorer tie rod
Sweet Ex!!, Im thinkin of takin the plunge and SAS'in my 99, How do those Coils ride? How do you come up with the linkage? I'm in between Leafs or coils, Thanks in advance
the build thread in my sig will answer allot of questions.:)
specs
Frunt
Rear
what tires are those?
Parnelli Jones Dirt Grips
dude whats the trick to mounting the KC lights on your cowl, from what i can tell on mine is the cowl is welded to the rest of the body. The lights look bad ass there and was thinking about moving mine to that location
dont do it. the glare is horible! i have removed them.
SAS with radius arm flex
From the pics it looks to have great flex. Does it? Is is stock bronco style or does it have a wristed radius arm? I'm doing the same swap. I was concerned about that style of front suspension and how it articulated in this application. What's your thoughts on it? Would you change it?
Any help would be appreciated.
Well. To answer the first question, i would say read the first post as you will find your answer has been, and always will be there. ;-) lol.
To answer the second question. No i would not chang it at all. Unles i get a dana 60 and some coil overs.
So I was going to update this but it seems all the pictures are broken does anybody know how to help fix the pictures?
thanks to photobucket I hope everybody quits using them and they go broke.
roscoe
