oops! CS and QL not recommended together unless the CS are 1" or less.
At this point, it sounds like QL w/oem springs only. Coilsprings should be used alone. The only diff between the two is - well two diffs - QL maxes out at 2.5" and Coilsprings are not adjustable.
You know, you could use QL in the front with oem struts and CS on the rear oem struts... or vice versa. This shop only recommended I change the front to oem springs. I'll take pics when it's light out...
they say you lose travel and get a bouncy ride - which I experienced personally. right now, they both cost about the same if you buy QL all around, or CS all around.
They're supposed to be adjustable from 1" to 2.5" They suck with anything other than oem size springs. Mine is in right now getting things adjusted... What is the part number for your rear springs? Mine are for sale...![]()
Donner: Are the QL's really adjustable height? I was always told it was just adjustably ride comfort. If the height is adjustable then way cool.
I still love my 3" coils up front. Still need the rear!
Anyways, I got new wheels and tires, 285/60's on 18x9 XD Series Black Hoss wheels. No rubs, no problems. Basically the same height as the 265/75/16 but quite a bit wider. If anyone wants my 16x8 pro comp 8069s(4" bs) and 265/75 Terra Grapplers they are still like new. I don't want to split them up yet btw.
