Explorinum
- June 5, 2019
- Location
- NY Area
- Catskills
- 2020 ST
I went outside to throw something [a light bag of microfiber towels] into the cargo area. Hit the button on the outside and the liftgate opened up normally.
Hit the button to close and it would not even budge a little and would just give the alert tones. Keyfob was in my pocket all along. The setting is set to open and I have never set the height adjustment nor do I use the 'kick' feature.
Manually closed it and tried again to open it with the button. Now it won't open either - it does unlatch though.
Did the manual open/close and tried it with the keyfob and the inside button also - same results - will not open but does unlatch.
Hitting the button on the liftgate will not close liftgate either.
Left the car off for an hour and tried again - same results. Moved it from point A to point B in the driveway for the heck of it and am still in the same boat.
The owner's manual only mentions obstacle detection but there isn't any.
Has anyone experienced this or have any insight as to what may be going on [or what I may be doing inadvertently (or incorrectly maybe)]?
Thank you,
Jay
Thank you,
Jay
