adamsbro2
Bryan
- January 30, 2002
- Twin falls, ID
- 93 XLT
To me that would be best but I would do the front first.cant comment on moab but your talking about being able to lock all four tires, you cant get more traction than that....idle for all situations except sharp turns and even then you can manually unlock the front one hub and turn sharp with 3 wheel drive.only way to get all four locked and be able to turn would be a selectable front and rear.you dont wanna do that to the d35 if you plan on sas.keep the front cheap for now.
Why I say front first is because the rear is ls and as long as both tires stay on ground you dont gain much by a locker because its a ls.the front is open, you gain there with a locker and front tires seem to leave the ground more (rock ledges. .) And you can trick the ls rear by applying the ebrake to act more like a locker.
My main concern is if the lunchbox in the front will take the abuse of climbing ledges like what may be found on trails such as Pritchett Canyon?
