LOOKIN FOR PRE RUNNER LIGHT BAR | Ford Explorer Forums
XJAR
warrington PA
91' EXPLORER 4.0 4X4 XL
I HAVE A 91 EX. AND IM LOOKIN FOR A PRE RUNNER LIGHT BAR . OR BAJA BAR , DOES ANYONE ONE HAVE A PIC OF THERE TRUCK WITH IT ON AND WERE I CAN GET ONE, OR DOES ANYONE HAVE PLANS TO WELD ON TOGETHER
bar
You can get universal "prerunner" style light bars that bolt to your existing bumper from s#ittybilt, fabtech, and a few other off-road manufacturers. The smittybilt one might be the easiest to get since alot of local truck accessory shops and 4x4 shops carry them.
You can also just replace your entire bumper with a James Duff prerunner bumper. www.jamesduff.com
I started with a Explorer Pro Comp "universal" light bar and made my own mounts.
Dead Link Removed
One thing I did learn is in order to keep the bumper/bar from shaking while going down the road it is necessary to weld the bumper brackets together. There are two brackets on each side of the bumper. One is the support for the corners and the other is the actual mounting bracket. The brackets flex between each other no matter how tight the bolts are so I just welded them together from the inside and now it is solid.
