danwaters
- June 1, 2003
- Fallbrook, CA
- 97 Explorer 5.0 limited
I'll give you a couple tips before I ask a couple questions because I am very curious as to why you're extending the track width so drastically. First off where you lower control arms bolt into the sub frame weld unplated washers on the front holes. The frames always rip apart there even without wide arms. Secondly use a piece of 1.5 or 1.75" OD tubing preferably 0.120 wall at least to make a crossmember to brace the aft lower control arm mounts because those push inward towards each other as well. Lastly, For the upper arm gussets weld some 1/8 or 3/16 plate cut in small triangular pieces that weld to the front of the mounts and go down the frame a little. All 6 rangers/explorers I have had crack there. My first 2 peeled completely up and off the frame. I am glad you are not taking the constructive criticism in the wrong way intended, but you need to seriously rethink how wide you are making these arms. I am not saying that it wont work because it may for a while before they fatigue and bend/rip/break, but what size shock are you running? Any reason for going so wide in the front because inversely from what you may think you will end up losing stability and structure at that width plus I doubt you will get any more wheel travel due to your limiting factor most likely being your shock. Having the vehicle sprung at the extension of a factory LCA is pretty sketchy. Are you familiar with suspension design at all? Did you alter the angle of the lower control arm balljoint during your extension to achieve proper geometry? Anyway, I feel like I am kind of picking on you now and I don't intend to. I just don't get what you are trying to do by this project. Especially if you just have some gravel roads and mud pits. All the luck to your project.
