Ninjasupahsquid
- May 25, 2024
- Rathdrum, ID
- 1995 Ford Explorer XL
Hi, My Name is Ryan and I currently Own a 1995 Ford Explorer XL (Pictured Below). Her Name is Bessie.
Bessie has 207,000 miles on her chassis
133,000 Miles on the 4L OHV V6 Engine out of a junkyard 1996 explorer
207,000 Miles (Unsure) on the Ford 4R55E Automatic Transmission
130,000 Miles on the Borg Warner 44-05 Transfer Case that I recently replaced last November Because the Original was stuck in 4WD.
I have been Slowly Replacing parts on Bessie ever since I've owned her in April of 2023 and I've fallen in love with 2nd Gen Explorers. So much so that I want to get another one to replace Bessie.
So. Here are my requirements
1. Has to have a 2Door 2nd gen body (Like Bessie)
2. Has to be 1997-2001
3. Any Trim package above XL (I want power doors, mirrors, locks and windows)
4. Must Have the 4L SOHC V6
5. Must Have the Mazda M5OD-R1HD or the M5OD-R1 (Just want the 5speed)
6. Must Have the Borg Warner 44-05 or the Borg Warner 44-04 Transfer Case. (Snow is a *****)
7. Interior Must be in Ok Condition (Doesn't have to be perfect but nice enough)
I'm not sure if ford ever made a configuration like this from the factory. However I am willing to custom build what I want using a 2wd explorer if possible. Just have some transfer case concerns that might need to be addressed
The Borg Warner 44-05 Transfer Case has Control Trac. Meaning it utilizes computers and sensors to detect when the rear wheels are slipping and when to send power to the front wheels. I'm curious whether this is done in the main ECU or if there is a secondary computer that does all this. Will I need to do an ECU swap? Can I use an aftermarket Custom ECU? is this even Possible or do I need to look at the Borg Warner 44-04 Full time AWD transfer case and will that mount to a M5OD-R1?
I also was wondering how hard it is to front axle swap a 2wd car. Are the mounting points the same? Can I rip the front suspension and diff out of my 95' explorer and shove it in a 2dr? are the torsion bars the same? are the upper and lower control arms the same? or is everything completely different and I'll need to look in some junkyards.
At the end of the day I Just want a 2nd gen explorer with a 5 speed and 4WD Or AWD. I'm hoping that is possible
Any insight or ideas is greatly appreciated
Many Thanks,
-Ryan
Many Thanks,
-Ryan
