CodyN
- November 4, 2009
- Fargo, North Dakota
- '95 XLT
Hello all, I recently purchased a 1995 XLT Ford Explorer from a friend. The vehicle has a kink or two to work out, but the most important safety issue I have to address is the lack of dash lighting(including the hvac lighting). I searched through the old posts and found some tips for the gen I vehicles in which the rheostat and headlight switch were one assembly. Usually replacing it seemed to fix your problems. However my 1995 has separate units for the rheostat and switch. I am able to get functionality out of the rheostat(dimmer) when the headlights are on in that I can dim the compass and temperature on the overhead display. I can also use it to turn my dome lights on and off. I just don't have any dash lights. I have found no bad fuses. Would replacing the headlight on/off switch potentially fix my problem? Any help or suggestions would be greatly appreciated. Thanks -Cody
