aasu
- January 24, 2021
- savannah
- 2014 ford explorer - v6
My daughter has a 2014 ford explorer v6 (not sure of model level). I didn't get a chance to look at the explorer so this is all second hand info.
She was complaining of the explorer engine shutting off at stoplights and then the low oil pressure light coming on. Her boyfriend checked the battery had 12V at rest, did a little research and said it could be the fuel pump. Due to fuel pump being in the gas tank he didn't want to do that repair. Forward about a week and she takes it to the dealership.
They run diag on battery and oil pressure and find the CCA at 350 and an oil leak at the timing cover. Their explanation for shut off doesn't make sense to me but I'm not familiar with the newer electronics.
1. They said the low CCA was a sign of a bad battery, which the battery management system saw and shutoff the explorer to protect the system. Remember this was happening at red lights after the car had been running.
-- yes, Low CCA is a weak battery which should impact starting but does the management system actually shutdown a running car just because the battery is weak?
-- Shouldn't there be a bad battery light or warning somewhere?
-- Is there any way to turn that shutdown feature off? She's could be in the middle of 5 lanes of traffic when shutoff occurs. Now I know Ford does this for a reason but I'm more concerned about her safety than her computer having a hissy-fit.
2. Wouldn't it be normal for the oil light to come on when the engine shuts down?
3. Would any of this be reported on a code check on the explorer via the OBD port?
Fortunately she has a warranty that covers all but about $600 worth of this work.
Thank you
Thank you
