Does anyone know the testing procedure on the brake fluid level switch in the master cylinder reservoir on 06 explorer ltd. My low brake fluid light came on with a full reservoir of brake fluid. Thanks
Is it a two-wire switch? If so, unplugging the harness maybe turn the dash indicator light off. So that would help you at least eliminate the switch from the cause the light is on.
