- April 2, 2000
- Greenville, MI
- 98 Mountaineer 5.0 AWD
There is now way for the lowbeam wire power to back feed to anything in the car as there is a relay to stop it. I have no idea where you would place this diode if it were necessary, which it isnt.
With the KC relay set up the power for the low beam comes direct from the battery, not the high beam wire. All the high beam power wire does is activate the relay.
Now when you use a high power harness, which is the only way to get full power to the headlights, you are adding another relay into the system that power can not backfeed through. All the diode does in the high power harness is prevent the high beams from going on when you only have the low beams selected. the power strokes guy mentioned that it activated the relay for the low beams but I think it actually powers the low beams. Which isnt a bad thing since the high power wire harness is up to the task since it has heavy duty bulb sockets and heavier duty wire and is isolated from the small guage headlight system by the relays.
The reason Dan had a problem is that the diode was incorrectly installed. As he said.
