Badfishforty
- September 6, 2022
- Albany, Oregon
- 1994, Explorer limited
Ok, so I had some pinging going on so I changed my spark plugs and wires the. Changed the oil and put some power punch in replace of one qt. of oil. Well I tried to start it and had major misfire going one so I checked all the gaps on plugs. Took some time and lots of thinking and found out I messed up the spark plug wire firing order up too lol. Fix that and she started right up and theirs no more pinging, but…… my oil pressure is on the low side now, always. The needle moves from the “N” in “normal” to as far as the “O” in “normal” on the gauge. Check engine light come off the and on sporadically. What should I do? Redo the oil change and make sure the filter it absolutely saturated and fill? Cuz I thing that’s part of the problem. That and starting it with the misfiring and it not building proper oil pressure.
