fastpakr
- February 18, 2005
- Roanoke, VA
- 99 4wd - 5.0/4R70W/BW4406
I'm at my wit's end with the final stage of the '99 Explorer 5.0 transplant into my '99 Ranger. Everything is installed, the truck is inspected, etc. If it ran right, I'd be done...
But it doesn't.
I'm getting about 13" of steady vacuum at the intake manifold. The engine is a fresh rebuild, and it's all stock except for a high lift/low duration cam (Comp Cams 35-510-8 / XE258HR, specs here) with matching valve springs and corrected length pushrods, plus a phenolic intake spacer.
Because of the low vacuum, I've got a crappy idle and awful off idle power. Brakes don't work well at all.
No codes at all. I've checked for vacuum leaks. While chasing down possible other issues I've verified fuel pressure and that the injectors are all firing. Fuel pump and filter are new, pressure is around 65psi. O2 sensors are new. Plugs are Autolite iridium (XP104), wires are new stock Motorcraft. Using the Torque app, IAT and ECT numbers look correct. EGR tube, valve, and DPFE hoses are new. The engine ran okay when I pulled it from the donor, so I have no reason to suspect any of the sensors or wiring that came with it.
What on earth am I missing? Idle quality is awful. It stalls sometimes when shifting into gear, and struggles with a warm restart (a WOT flood clear gets it to start). Power is decent above 3000rpm, but pretty terrible otherwise.
I took it to a local shop that I trust today, and they want to blame the cam. I'd accept that, but it's a pretty mild grind and others here have used the same one without reporting any of these issues.
But it doesn't.
