Mach Audio System Questions? | Ford Explorer Forums
PanamaVR4
Moline, IL
'00 Limited
I am taking delivery of an '00 Explorer Limited with the Mach audio system. I am curious what it consists of and what the stock subwoofer size is. Does it sound fairly decent for a factory sound system. Any information would be helpful. Thanks all!
Welcome aboard Tom
Somebody from my neck of the woods:D Sorry dont no nothing about your ride to new for my blood:p Just wanted to welcome you:D
Go to the audio forum
and check out "self test":D
Hi,
I have a 99 limited with the Mach Audio system. It isn't bad for a factory system but it can be much better.
I believe the stock sub is an 8 incher and it does a decent job. I am looking to replacing it next. I want lower bass than it provides.
I already replaced the door speakers. That is a must, IMO. The factory speakers are the weakest link. The front speakers are slightly better than the rear but they both stink.
I am also replacing the radio. Mostly because of the stupid display problem. It isn't a bad radio but I like to see what stations I am listening to and what time it is. :(
There is an Audio FAQ here that you should read. It will answer a lot of questions.
Glenn
FAQ
I cant seem to find the audio FAQ? Can you point me in the right direction? Thanks!
Hey,
Sorry it isn't called a FAQ but that is basically what it is. Look at the start of the audio forum under Quick Reference For Audio Forum. This link might also get you there.
Dead Link Removed
Good luck,
Glenn
AM reception is very poor, and I don't believe it is the antenna.
