xplor_off-road
- February 27, 2005
- WV
- 1996 2Dr. Sport
Hey all, just spent the day trail hoppin' mostly just tryin' the T-case mod I installed on Friday. It's so nice to shift into 4 high & low manually as well as shifting the t-case into neutral which was kinda imposable before! And the best thing was it only cost me $15, yeah only fifteen bucks! I had the Borg Warner 4406 stock I think it was. Anyway I trashed it one day being stupid LOL. So I found a Borg Warner 1354 in a ‘96 Ranger and swapped it in with the Ranger front drive shaft..Now that cost me $350. But it only had 28k miles on it. But after the install it would never shift into 4 high only 4 low!!? So I put on my Hillbilly engineer hat & started thinkin’ & what I came up with was this. The front axel disconnect was a BIG problem. So I removed it and slid the shift fork over. So that the front axel would always be connected & held the fork there with a couple good welds! & just simply reinstalled it. The next Problem the T-case shift motor. So I just removed the guts of the motor as well as the back “plastic” cover & found a steel gear that done all the shiftin’ & in the middle of that gear was a place where a 9/16 socket fit snug over. So again I welded the socket there solid & came off of the socket with a 4” “Craftsman” extension & welded it solid. And then just used two universal joint extensions to get the right angle. And used a 12” extension that would run all the way up through the floor between the seat & consol…If anyone attempts this just be prepared to have a good welder and weld all the joints except the U joints! use some good quality 1/2 tools. All I know is I gotta be the first one to try this, who’s next! LOL. I will provide some pics after the clean up. I’m very happy, it held up very well. This will work on any electric shift t-case. The only thing I don’t like is that the t-case turns all the time now as well as the front drive line. But keep fluids clean & they shoulden't be a problem here. Anyway to shift to high, low or neutral now all I have to do is "turn" the shifter counter clockwise in quarter turns from 2wd, 4-high, neutral, and 4-low
