cloaked_chaos
- October 4, 2006
- Phoenix, Arizona
- 94 4x4 Limited
I recently bought a 94' Limited Explorer with 114k miles. Everything is in great shape and nearly everything works like it should. The problem that I am having is that the map lights will not turn off. Everything else on the overhead console works just fine, including the temperature/direction display, and the mode button. When I push the buttons for the map lights nothing happens, they just stay on all the time. I had to put an insulator in between the bulb and the metal because I didn't want to remove the bulbs for fear of losing them. What could possibly be causing this?
I removed the console and inspected the circuit board. It seems to be in perfect condition with zero corrosion. Does anyone know if there is a component on the board that could have gone bad that I can replace?
Also on a separate note, the glass covers for my fog lights are broken and I cant seem to find replacements. I read somewhere on here that they may have been made by Hella, but I don't have any part numbers or anything.
