VSS goes into the t case
the 5.0L computer wont care if he's in low range
ball pine hammer for your oil pan
sledge hammer for the firewall lip and drivers/passenger floorboard, seriously move that sucker 3"
I have a 88 BII with a body mount reduction, thats right the urethane body mounts I have lowered the body to the frame........I still clear all this stuff and I have an early james Duff axle pivot bracket that is CAST (thick SOB)
You can make it work! consider raising the engine just a bit (spacer on top of L&L mount) to help the trans clear and the oil pan / ttb bracket
TM headers were a lifesaver
IU ditched the exhaust heat shields on the passenger side, they just rattled anyways
my floorboards and firewall were punished to fit this in there, nothing carpet wont hide LOL
I also had to add about 1/2"-3/4" to the height of my trans mount, but then you have to remove the t case to get my trans mount off LOL its like a jigsaw
next I plan to go atlas II or 4406 manual....that should be fun!
My rear driveshaft and pinion angle are semi extreme, but nothing the u joint cant handle, and even with 35's and at 75 mph, vibrations are minimal
