colmnfamily
- August 9, 2009
- SYkesville, MD
- 2004 Explorer XLT 4WD
Hello,
I am new to the forum and thought I would try my question here. This is for a 2004 Explorer XLT.
Was getting poor air flow from front vents on all fan speeds, but heard blower motor running properly...based off suggestions on another website, i unbolted the blower motor from under the dash. I looked up into the (what is this area called?) and saw from what I can tell is a rectagular piece of plactic with some foam on it covering the intake hole. There was also some debris in there (napkin pieces, leaves). I was able to push up on the piece of plastic and pull this debris out. The piece of plastic just seems to flop around, not attached to anything.
Is this piece of plactic the damper door?? I saw on another forum that the damper door that engages when MAX A/C is set sometime comes off. Or is this some kind of filter??
Now, even with this unknown piece of plastic still covering the hole, the vents are now blowing air properly! Have appropriate air flow at all fan speeds.
So now this leads to another issue. Now have proper vent flow, but MAX A/C does not engage. It is my understanding that it engages by means of a 'vacuum reservoir' and that you would hear (which i have in the past) an audible "fwoomph" sound when it is working properly. I do not hear that now. Now, if the damper door has fallen off, would I still hear some vacuum noise or nothing at all? Other posts indicate a hose may be disconnected from the reservoir or it may have water in it. I cannot seem to locate this vacuum reservoir.
Also, what is the black capsule-shaped housing (about 6" long x 3" in dia.) located just to the left off the blower motor under the dash?
Wow...I know this is alot, but any help appreciated!
Thanks
JC
Sykesville, MD
Thanks
JC
Sykesville, MD
