scotty7676
- November 11, 2007
- FL
- 2011 Explorer Limited
Hey all, I think I'm screwed, but I'd like to have an idea of what's going on before I take it in to the shop.
I have an '04 XLS with the plain jane air/heat controls and about 2 weeks ago, everything works (heat, defrost, etc), but the max a/c does nothing. So I finally crawled under the passenger side and started testing vacuum lines and actuaters. Everything checked out ok, so I took out the actuator that controls the recirculator door and noticed the arm that controls the recirculator door was just flopping around like it wasn't hooking up with the door mechanism. I pulled it out and noticed the end is broke off.
I thought maybe I could just buy the arm and slide it in there and be done, but I stuck a screwdriver in the hole and there isn't anything to hook up to. I'm guessing something inside there has busted. Any ideas what to do? I don't see anyway of taking it all apart besides pulling the dash out, but maybe there's a trick? Anyways, I have attached a picture of the broken arm, and hope maybe someone can point me in the right direction (sorry the picture sucks). Also, found two part numbers on this:
4246-A
1L2H-18735-A
Thanks!
Scott
4246-A
1L2H-18735-A
Thanks!
Scott
