im not really sure... when my truck was a stock 4x4, and we had an ice storm a few times a year and i had to drive to work.. i would run it in 4-hi at 60-65 for a 55 mile trip one way.. As far as the specifications and everything else read out, as long as everything is balanced and maintained well, you should be able to run in 4-hi just like you do in 2-hi because there is no reduction in ratio going from 2hi to 4hi, all your doing is engaging the t-case and front driveshaft. my truck is a 5 speed stick and 4lo in 5th gear floored, about 25 was max..
now thats its full-lock front and rear, i wont attempt anything over about 40 in 4hi
