I would agree I think the codes would help immensely. Bu with the holidays don't have the cash to tow for a code for a repair I may be able to do myself. If someone in central Florida has a reader I can meet up with and pull the codes, that would be great!
So decided to buy one, posted a three in Under the Hood asking for some reccomedations Looking at Launch and Autel. Leaning toward launch right now. Any thoughts?
I saw that one, but it says that it does not do trans trouble codes. So I looked at the 702/3 series. But with other family cars. The 802 was a good all round.
Hi, get an app called Forscan. I believe it can do bi-directional controls. Then get a cheap bluetooth dongle ( I use BAFX, but many others may work). There is nothing better you can use for Fords. Also, it is free.
OK so added some Mercon and a few things to diagnose the problem. It appears that there is fluid coming from the bell housing plug. Trying to attach pictures on my phone. Can't figure it out. Keeps asking for URL
I think the reason that V8 parts/transmissions are harder to find is that they tend to not break down as often and get parted out. Plenty of SOHC parts cars around.
Post up the codes once you get them, doing any repairs before that is just guessing and that can get expensive. The leak from the front is not a good sign as it will require the removal of the transmission.
Probably, I've found that finding a V8 in my area with a blown engine/trans that the body isn't junk on is an absolutely awful job, been looking for months and wouldn't have anything I've seen.
