MFT(Sync2) to Sync3 V3.4 Upgrade Minor Issue | Ford Explorer Forums
Edmonton AB
2013 ford explorer ltd
Hi Everyone,
Does anyone have the same issue after upgrading to Sync3 Ver3.4(Dual Climate Control)button
doesn't turn on once turn off(Video Attached). Everything works perfectly except Dual Climate control
on and off.
Dual climate control repeater is "ON" in APIM: 7D0-04-01-0103-0200-00E2
(2013 Ford Explorer LTD)
Kindly advice if anyone knows how to fix this problem.
Thanks in advance
This discussion is only MFT or SYNC2, not SYNC 3
What is your vin. Please take a photo of your APIM as built data and send me. It looks like a conflict in APIM as built data configuration
Curious what features were gained by going to 3.4?
How did you upgrade to 3.4?
Here is the config I used on a 2013 upgraded to v3.4. I do think there was still an issue where the dual climate button always reflected the opposite setting vs. the physical button but everything still worked.
Save as a text file then import to FORScan to see the correct formatting
Code:
;Block 1
7D0G1G1AA2105016E18
7D0G1G20083400012AF
;Block 2
7D0G2G155531204C058
7D0G2G28200A020102D
7D0G2G30405E5
;Block 3
7D0G3G10100000200DE
;Block 4
7D0G4G1010001000BE9
7D0G4G20001DE
;Block 5
7D0G5G11A2C1A2C2B94
7D0G5G2FCDA
;Block 6
7D0G6G1815F
;Block 7
7D0G7G10A003300001C
7D0G7G2000017700067
7D0G7G3005656880015
7D0G7G4886A
;Block 8
7D0G8G10000000000E0
7D0G8G20400000000E5
Mine does the same, on touch screen it shows exactly the opposite to the climat controls buttons on dash. Most is working fine, but some, once activated on touch screen impossible to turn off except by using buttons on front dash.
Code:
;Block 1
7D0G1G1AA2105016E18
7D0G1G20083400012AF
;Block 2
7D0G2G155531204C058
7D0G2G28200A020102D
7D0G2G30405E5
;Block 3
7D0G3G10100000200DE
;Block 4
7D0G4G1010001000BE9
7D0G4G20001DE
;Block 5
7D0G5G11A2C1A2C2B94
7D0G5G2FCDA
;Block 6
7D0G6G1815F
;Block 7
7D0G7G10A003300001C
7D0G7G2000017700067
7D0G7G3005656880015
7D0G7G4886A
;Block 8
7D0G8G10000000000E0
7D0G8G20400000000E5
What is the trim level of that 2013 Explorer this APIM config for?
Mine APIM config looks similar, especially starting block 5, mostly because mine 2012 Explorer originally had only four blocks with SYNC 2. The difference is that I dont have block 8 at all.
7D00101A22105030AAE
7D00102028300000A69
7D00201575301048009
7D00202020880000065
7D002030005E1
7D003010000000300DE
7D00401010000000BE8
7D004020003E0
7D005011A2C1A2C2B94
7D00502FCDA
7D00601805E
7D007010A003300001C
7D00702000017700067
7D007030056568C0019
7D00704886A
7D00101A22105030AAE
7D00102028300000A69
7D00201575301048009
7D00202020880000065
7D002030005E1
7D003010000000300DE
7D00401010000000BE8
7D004020003E0
7D005011A2C1A2C2B94
7D00502FCDA
7D00601805E
7D007010A003300001C
7D00702000017700067
7D007030056568C0019
7D00704886A
I believe it was a Limited
The dual climate button issue (as well as the rear climate on/off being reversed, there being a max defrost button that doesn't work, and heated steering wheel showing up in the AC sub menu if you have it) are all artifacts of using 3.4 on a CGEA 1.2 vehicle. I've asked in multiple groups and all CGEA 1.2 vehicles have these issues if they have the associated equipment, EG 13+ Taurus, Flex, MKT, MKS and 11-15 explorers. It will have to be fixed either via a mod or if Ford happens to randomly fix it even though 3.4's support of legacy CGEA 1.2 is basically just a carryover of the 3.0 base code apparently. No CGEA 1.2 vehicle ever had or will have 3.4 as far as anyone can tell.
