rcrawley
- May 7, 2012
- Maysville, Arkansas
- 2000 Expolrer XLS
I think there is a connection. Engine has been running rough for a while. A few days ago I replaced the thermostat. When I removed the radiator hose some coolant spilled on top of the engine. After I was finished took the truck out for a test drive.
The check engine light began to flash and the engine ran rougher than before. Could the coolant have agrivated a sensor problen on the top of the engine? Code P0303 was present before but light never flashed.
The code reader is also flashing the following: CAT, EVA, O2S and HTR.
Checked the coil. Primary resistance was within acceptable range, Secondary resistance on all pairs was around 14.3 while the range should be 6.5 to 11.5
