Bobbyd3633
- April 29, 2016
- Winston Salem, NC
- 2003 Explorer XLT
I have a 2003 4.0 SOHC XLT 2WD that's misfiring on cylinder 1 at low RPM. I had the engine out and replaced all the timing chains and tensioners. Reinstalled engine, started it up, ran fine until it warmed up. When idle dropped it started missing. Put an engine analyzer on it and pinpointed it to the #1 cylinder. It only misfires at idle, at RPM over 2000, no misfire. I've changed plugs, wires, coil, injector pigtail, and injector. No change. Has good compression and leak down. I hear a faint rocker noise, so I removed the intake and valve cover suspecting valve spring or rocker trouble. Everything looks fine, but ordered new valve springs just in case. Turned motor over with the starter and all looks normal. I'm stuck, it has good compression, so I'd say the valves are seating normally. Leak down was good, so I'd say the rings are fine. The only thing I can think of is a valve spring problem, but they are not broken, maybe lost rate?
