Kage.
- July 22, 2014
- STL area
- '99 Mounty V8
Bray is a pretty good dude to hang around with, and even though I wound up going with leafs on the front of my ranger, his build kicked me over to the RBV platform from the Jeep world.
I went back and started at your photos a bit more while comparing the setup I have on my truck frame (same as the Gen 1 ex's). It looks like the torsion bar frame winds up hanging down lower that the TTB frame, which is where my confusion was happening. I might be able to go with a high steer setup on my drag link, but I can see how the tie rod could cause some issues, which would then wind up causing issues with the track bar If i had to guess.
Couple more questions for ya.
Did you wind up swapping the C bushings, or did you just leave it at the 6° caster?
Got a link to those front bump stops?
Did you wind up using the 3.5 or 5.5" springs?
For your front sway bar, you might want to look into using a torsion bar from a yota and build your own ends. I believe that they are long enough to use with our frames, but I don't have one in front of me to check right now.
Little info for you Junk Yard Sway Bar on Pirate Cheaper than a anti-rock setup if you can find a bar easily up there.
