cross6
- February 26, 2008
- Baton Rouge, LA
- 2004 Mountaineer
replaced*
Ok - clunk/snap ONLY when backing out and turning, like in a parking lot. It's an initial clunk, then a snap a few seconds later.
This weekend I replaced:
Both lower ball joints
both upper ball joints
inner tie rods
outter tie rods
bearings
rotors
brake pads
greased slide pins
sway bar end link bushings.
Checked rear end brakes and the parking brakes - all fine. Rear end was rebuilt recently and didn't phase the noise.
So after all of that work and an alignment - the noise is the EXACT same! argh!
Now I'm stumped. lol. I also got under the truck and looked at motor/trans mounts and u joints and all seemed tight.
I can feel the noises in the brake pedal.
inner tie rods
outter tie rods
bearings
rotors
brake pads
greased slide pins
