DidiDavis
- July 18, 2010
- Davis, CA
- 1996 Explorer Eddie Bauer
I just posted this on another thread but got no response. I hope that you can help me. I'm having problems with 2002 Explorer 4x4 automatic, transmission 5R55W. I'm not familiar with explorers, therefore some of the symptoms that I indicate here may be normal operation. I used an OBD2 reader and I have no codes stored.
Problems:
1- The O/D light is flashing very rapidly. It starts flashing some 5 to 10 seconds after starting the car, even without shifting out of P. It shifts fine through all the gears, including overdrive. I get around 2200 rpms at 70 mph. If I hit the O/D button, the car down shifts and rpms get at around 3000. The previous owner told me that he took the car to mechanic and the problem is the Overdrive Sensor. Is there such a sensor in this car? I've searched through the forum and found no reference to it.
Symptoms:
1-There's a little bit of jerk when shifting the gears, which I think will go away with a transmission fluid change.
2- Sometimes it seems that the shift is not as fast as it should be. There's kind of a delay when up shifting and especially down shifting. When I floor the gas pedal, it takes some 2-3 seconds to down shift.
3- There's a delay when shifting from R to D. It doesn't engage right away, it takes some 2-3 seconds to engage.
What do you guys think the problem is? Based on what I read I'd say I need a new solenoid module.... is that right?
Thanks
Problems:
Symptoms:
Thanks
