kydirtscooter
- June 6, 2018
- ky
- 2003 Explorer Limited 4x
Just a heads up for Ford (Motorcraft) bearings. Ford updated numbers on the front and rear wheel bearing "kits," both Chinese now. Prices have gone down significantly compared to the previous offerings.
Front wheel bearing part number has been superseded from 4L2Z-1104-AA which is an OE design level bearing "kit" including brake anchor plate bolts and bearing flange bolts (both with threadlocker applied and grade marked on the top) and ABS sensor pigtail.
The new shorthand number is still HUB-67 but prefix is G2MZ. The new front unit bearing assembly is now a "service level" design and no longer has Timken stamped on the inner seal tin, no longer is "majority content made in USA," has a glued in ABS sensor with allen bolt, and no longer has the bolt grade stamped into the hardware (still includes anchor plate and flange bolts).
The rear bearings used to be only available as a separate item from the hub and retaining clip. The OE design specification was for an FAG bearing made at various EU plants (often Italy). Within the last few years Ford concurrently offered FAG bearings and also a Chinese bearing, hub and retaining clip as a kit. As you may very well guess, the kit was only slightly more than the bearing itself.
This simply serves to hopefully save someone a trip to the dealer for parts expecting the Timken front unit bearing in the package and FAG sealed taper bearing for the rear. Ford decided to offer kits made in china.
