Peanut74
- November 25, 2010
- Prattville, Alabama
- 1997 XLT; 325,000 miles
I recently replaced the factory radio with a 2-DIN that had GPS. Rather than mounting the antenna outside the Ex on the roof I wanted to attach it to the mirror stem. I looked all over the internet but did not find anything I could purchase that would work.
The solution I came up with was courtesy of my grandson. He was sucking on a ring pop and the plastic ring part was just about the perfect size I needed. So when he finished it I cut off the little protrusion that held the candy off. I then put double side tape on the top and mounted the GPS antenna and presto I had solved my problem. The best part of all is that I can move or remove it any time I want to.
