whiteboi69
- October 17, 2010
- tampa fl
- 1992 xlt 4.0
its throwing a pcm cirkit malfunction code now so dos that mean the comeputer is fried ?
Heat up the balancer. If the balancer is cold (i.e. unheated garage) it makes it nearly impossible to press it off. As the steel has contracted on the crank snout. Warming it up a bit will allow the balancer to expand a little, and it will slide off a bit easier.
Case in point:
I had to install a new HiPerf (BhJ, SFI cert.) on my Olds350, it would NOT go on, no matter how much I tried. And I have the proper Balancer install tool/press! Well, I was working out side, in a covered carport. It was about 50 deg. outside. I took the balancer inside, put it in the oven @ 250 deg. Baked it for about 15 min. and went to go re-install it....it went on almost all the way by hand!...only the last 1/4" or so had be pressed on, and even THAT went on SUPER easy.....
Heat is your friend!
Ryan
This is how I removed mine...
Loosen the harmonic balancer bolt, the bolt should have about 10 threads left engaged with the crank....
And I know the following is going to sound weird, but just do it....
Remove a few of the bolts that are used to bolt the A/C compressor to A/C compressor bracket, and use THOSE bolts to go through the cast steel puller, and thread them into the balancer. The A/C Bolts are the perfect length, and the right thread size/pitch.
For pressing the balancer off the crank, use the 'flat' or 'top hat' shaped end on the center "pressing" bolt.
Place the flat end against the head of the harmonic balancer bolt.
Start turning the BIG bolt....
Eventually you will have to remove the balancer bolt as it will bottom out on the bolt before falling off the snout of the crank, but that iwll get you started, and you SHOULD be able to figure it out from there. If you can't figure it out, you PROBABLY shouldn't be swapping out your own timing chain.
Ryan
at the risk of sounding sarcastic (I'm not being really) left hand thread?
