SensRanger
- September 14, 2005
- Ottawa, ON
- 96 Ranger XLT 4x4 Xcab
My tranny (4r55e 96 Ranger 4L, 80k kms) seems to work perfectly well except for a small flare when shifting 2-3 and sometimes a clunk and delay when shifting in/out of reverse, especially in the winter, but never more than 1.5 seconds or so... but driveability seems fine. I started noticing the flare around the beginning of summer but it was so small I thought it might be normal somehow. Then I figured it was the common low pressure/ seperator plate gasket issue from the TSB and the detailed threads here, so finally brought it to a reputable tranny shop last week, which diagnosed the same. They updated it with the ford kit.....and it did not fix the flare!! Apparently there is damage inside, worn clutch packs likely or something.
Well they didnt charge me for the work but....how much time do I have left?? I have been backing off the accelerator just before the point where it would flare, and it drops into 3rd nicely. Is this a good thing to do? Will it extend the tranny's life? Should I pay for a full repair now, or will driving it (and slipping once in a while for sure) make for a more expensive repair later?
It really doesnt seem to be on the brink of breaking. The fluid was pink before the work, never seen the OD light flash, no CEL...they quoted me about 1000 cdn for the work...... any comments and advice appreciated.. thanks!
