firewolfm
- May 9, 2007
- Albrightsville,PA
- '94' X Sport, '92' XLT
:thumbdwn: I'm alittle baffled here?
I was on my way home yesterday and all of a sudden the truck began to lose power on this fairly long and steep incline going up.
It almost sounded like the truck was starving for fuel,but I had plenty of gas? It got increasingly worse then finally died atop the hill.
It was overheated and I let it cool down alittle while. When I started it back up the engine would not rev more than 2000 rpm? I started to try and make it home but after alittle distance it would stall again and not start back up for 10 or 15 minutes each time? Well I finally limped into a garage in the area I know and had the truck flatbeded from there.
I checked ignition and all seems OK?
I checked fuel supply and it's not the pump,and pressure is good at the FI manifold.
I started troublshooting the problem and it could be the PCM (power control module),but I have no way of testing it.
At this time I'm open to any and all input,I need this truck running ASAP
