delexploder
- March 11, 2012
- Greenwood De.
- 97 ford explorer sport
Nice
Did you change your N/V in your tune?
And what?
E.T. and mph!!! lol
and 15 lbs of boost?! i am very surprised that motor has lasted as long as it has
Time to stroke and get some BOB or BOA heads
I take no credit for this information, I did not make it up. I just figured out how to use it. It may or may not be correct.
I have found some interesting statements about exhaust flow and horsepower.
1. Straight pipe is said to flow 115 CFM per square inch of area
2. To avoid exhaust restriction the exhaust pipe should flow 2.2 CFM per horsepower. (I am assuming crankshaft HP)
These statements may not apply to all vehicles under all conditions, but they are interesting.
The statements are used with this formula.
The area of a pipe X 115 CFM / 2.2 CFM = Horsepower that the exhaust pipes can support.
(1/2 x True Pipe ID) ² x 3.14 = Area of pipe
To find area of exhaust pipe you need to know the thickness of the pipe wall.
16 gauge is .065
There are 2 walls for a total of .13
Subtract that from the pipe diameter.
2.5 inch OD - .13 = 2.37 ID
2.37 x .5 = 1.185 (half of pipe ID)
1.185 x 1.185 = 1.404225 (squared)
1.404225 x 3.14 = 4.4092665 (Pie'd) lol.
Area of 2.5 inch pipe with .065 thick walls = 4.4092665
(4.4092665 x 115) / 2.2 = 230.4843852272727 HP
Rounded 230 HP per 2.5 inch exhaust pipe per side.
Duals with 2.5 inch pipes should be good for 460HP
The below numbers would be with .065 wall thickness
So if my math is correct.
3 inch can handle 337HP per side
676 HP Total with duals
2.5 inch can handle 230 HP per side
460 HP Total per side
2.25 inch can handle 184 HP per side
368 HP Total with duals
2 inch can handle 143HP per side
286 HP Total with duals
I last tested my truck on the dyno a while back with 290 HP at the wheels when I was running 13.34, at the crank maybe 350HP according to 20% drivetrain loss.
Now with water meth running 12.9. I have not been able to test on the dyno but.... online calculators...
Maybe 380 HP at the crank.
Remember it takes 75 HP to drive the GT500 supercharger.
380+75= 455HP at Crankshaft.
Kind of puts things in perspective.
Wednesday I drop my truck off at the exhaust shop.
2. To avoid exhaust restriction the exhaust pipe should flow 2.2 CFM per horsepower. . .
