stock grill just pulled it in the garage
after removing all of the screws, tool tray and corner lights there are 4 pressure clips holding the grill in 2 of them are under the corner lights and the other 2 you access under the truck
with the grill shell removed from the truck, it would be a good idea to remove the egg crate plastic that is held in with 5 push pins
the grill, ready to cut the center section out
cutting the center out, with a sawzall
the center is now removed
again, center removed
placed the billet grill in, drilled the holes and test fitted
then taped off the center section
went over it with a red scotch brite pad = to 600 grit sandpaper
two coats of krylon fusion gloss black
dried and tape removed
all finished ready to re-install on the truck
re-assemble grill shell(may want to take the time and clean it well) and step back and enjoy
So yeah, sorry for my sloppy typing haha...Its really not to bad to install...
