- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Autozone clutch very expensive vs rockauto or the like
The pilot bearing is in the flywheel on these if you remove the flywheel then you do not need grease or bread to press it out
I’m not aware of a special tool needed to bleed the clutch master? Are you talking about releasing the hydraulic line from the clutch slave?
