19Explorer93
- April 12, 2008
- Dover, DE
- 93 Sport
ok so basically i can take the turbo i have a boost controller and a upgraded fuel pump and run up to 5 psi but if i want to run more i need larger injectors and a fpr. where you get your injectors from. also what psi a stock explorer run anyway. should be like 45 or something right. if so i might look into a rising rate regulator and wh carries a walbo 255 for the explorer
