my diy 4.0 ohv turbo build | Page 8 | Ford Explorer Forums - Serious Explorations
Sorry been a while the turbo sploder was sitting for a few. Plug wires went bad and it took my lazy ass a while to fix them. I installed some msd wires that were sitting around from my old 4.6L. Installingv the fmu when i get back to work monday. I don't think I ever posted the dyno video in this thread from a while ago...
well after a few weeks of tinkering with the fmu ive got it to run stronger. pulls good and dosen't rattle. Still needs an intercooler and a wideband to make further adjustments. Once the intercooler is on I will be thinking about turning the boost up. I'm also always looking for a larger T3 and plan to redo the hotside maybe for a little better flow and looks as I can Tig and Mig alot better now as my current kit was welded up with gasless flux wire. heres some of my other recent work
do you still have the pictures of how you mocked up the original manifolds? your pics in the first post are gone
Turbo Cat, thanx for just getting out there and doing this. Your thread cleared up a bunch of confusion for me. Now I'm seriously motivated. Will you please post a pic or two of your oil supply/drain solution?
The pics are on my other computer which has crashed. Feed is easy you just place a 1/4 npt T fitting where the current oil sender is and my feed is returned to the timing cover under the PS pump. I just tapped and threaded a fitting in. If i did it all over which I am planning to re-do the hotside Im moving the battery to the driver side and turbo to the passenger side.
OK... this is one sweet thread!!. I'm liking this!!!
So what I need to do this on mine is:
T2 or T3 turbo set for 5 - 10 psi
Adj fpr
21 - 30# injectors
cooler thermostat
cooler plugs
retard timing a bit
Anything I'm missing here???
I've read the whole thread and can't believe that this is it!!
How'd you fool the maf or map sensor thingy??
I SO WANT TO DO THIS!!!!!!
how much did the whole kit cost from start to finish? Where did you get the turbo and how thick are the flanges? Is there any other head work or is it just threw together and with low boost stock injectors?
It cost me about 200$ the turbo was 16$ and I actually made 5$ while I was in the yard by helping an older guy pull a caliper off a van. I have a few of them laying around. I am in the middle of rebuilding the kit for smoother design. I am also going to be duplicating the hotside if anyone is interested. I will have more details soon I started working on the jigs today.
im interested in a step by step with your build im planning on doing mine on the cheap and want it to last
Just a little progress here. As you can see in the second pics that is part of the current old kit under the jig.
where did u get your flanges for your turbo and did u actually route a down pipe down im looking forward to run a t3 t4 on like ten pounds in my two wheel drive mazda navajo what other parts have your upgraded like gaskets are they doubled up stocks or after market
I cut out the flange myself and the motor is completely stock.
stock gaskets and everything and how did u mess with the ecu to trick it into accepting boost considering it runs of vaccum and now its being forced air could u give me a list of everything used like the bov and wastegate and how much did everything cost from start to scratch any ideas where to look for a good turbo
Is there any updates for this thread????
lol I tried that, only I just took the ball off the bumper, and would you believe when my dad asked me about it I told him" ball? oh it fell off in the road, then he made me drive him to walmart and he bought another one. That very same day he took me with him to haul a bunch of scrap to the junk yard(trailer loaded, ford explorer rattling, and his foot.....to the floor):(
that ball mount removes 4 bolts looks cooler any way
Im getting close to building the new hotside. It simplifys alot of things and makes it easy to build.
